Leprechaun aka Rainbow Machine
jcpst
Rainbow Barf. 🌈
Kind of like the Data Corruptor, I just had to try it. This one I could see using more often.
I was reading about the Rainbow Machine, and saw that it has intelligent switching for both stomps. Tap for latching, hold down for momentary. So at the last minute I decided to add it.
It was kind of a pain to shove both relay boards in. I used low profile electros for clearance and mounting tape for insulation. First I shoved the DPDT under the board.
Then I put the Bypass on the footswitches.
I put more mounting tape on the enclosure lid where the relay board and the switched jack make contact.
I used a Peacock Ore enclosure, paint pens, and an epoxy resin finish. The resin didn’t set perfect, but it’s not bad either.
