Leprechaun with Expression Pedal ?
Dali
Hello builders,
The building docs mentions on page 4 "Wiring diagram with expression input jack".
Anyone here made that build? Is it worth it?
There is no information about the kind of Expression pedal compatible or that you need to build to make it work.
Any information is appreciated!
Pretty much any expression pedal with TRS connection should work, I believe. The exp pedal controls an fv-1 parameter (pitch). The pot of the exp pedal creates a voltage divider which sends a voltage to the fv-1. So the fv-1 doesn’t care what the total resistance value of the exp pedal is because any value will still make the voltage divider.
