owlexifry
i am trying to design a power supply. but i am not very smart.
i have a few limits with the design (and there’s a few reasons why..)
1) i’d like to use a LM317 voltage regulator since it’s available everywhere and low cost.
2) i have to use a 50V AC tap (reasons below) - unless i try to use a separate 150ma (24VAC sec) transformer (would rather not)
3) aiming for ~+33V DC supply
4) the circuit to be supplied apparently draws 84ma (per multimeter ammeter)
5) i did some measurements - the ‘50V AC tap’ rectifies to about 64V DC (no load) - (with a bridge rectifier + 1uF cap)
my understanding is that LM317 voltage max rating is a differential of Vin to Vout (40v max) rather than an absolute 40V max at Vin.
so, I’m assuming the LM317 won’t melt if it sees 64V DC, and also assuming that a 39V zener at Vin can limit this input voltage to 39V anyway…?
here’s my first draft schematic:
would really appreciate advice on this design.
a lot of spitballing on the values here… i’ve been trying to follow datasheets / examples i’ve been seeing online.
another problem/annoyance
- the rectified 64V DC is going to require at least 100V rated (or more preferably) filter caps before it gets to the regulator.
that's getting expensive - almost becomes cheaper and simpler to just use a separate 150ma 24VAC transformer.
…unless a zener diode can clamp voltage before the filter caps?
(not sure if that would even work)
my understanding of zener performance is limited and i’m not sure if they will truly and reliably protect the regulator in the way i understand they do/might…
this is all for a project i started about 18 months ago and have been neglecting (for pedal builds of course) because this power supply problem has been a real challenge for me to address / understand.
the project:
MK2C+ inspired preamp build
- lead channel only. (no rhythm channel / switching)
- with 5 band EQ based on original (but with transistor gyrators instead of inductors)
(this is what the power supply is for)
- tube preamp runs off 300VAC + 6.3VAC windings (hammond 369BX transformer)
- and yep, there’s a spare ‘50VAC bias tap’, so i thought hey why don’t i just use this tap instead of trying to squeeze in a (24V) transformer - for the EQ circuit.
the preamp sounds amazing.
when i first finished it, i finally i got to hear that mesa mark lead overdrive sound. it's astounding. a unique complex flavour, different to the marshall/SLO/5150 topology that i'd been used to.
(into FX return, 4xEL34 100W Peavey))
but for high gain/metal riffs/styles, it really needs the 5 band EQ, to bring back the low end (and some top end), after cutting it at the front end (necessary to keep the overdrive tight)
and the EQ kinda needs to be high(ish) voltage.
i first tried an opamp based eq circuit.
- TL074 @ 9V - not too good, @12V improved, but still lacking. could hear the lost dynamic, definition (vs no EQ). and the highs were a bit 'harsh'
(into FX return)
then i got hold of some OPA4134 ICs.
and damn, they’re pretty good. noticeable improvement over TL074.
(into FX return)
then i found a schematic for a transistor gyrator based circuit, intended to run at ~+33V, that looked pretty much bang on vs what i’ve seen in mesa boogie schematics for the 5 band EQ.
so i went ahead, did a vero layout, and built it.
- using a separate 9V supply with chargepump circuit to boost to +33V - and heck yes, this sounds so much better than the opamp circuit (no demo yet, sorry)
and since then i’ve been kinda stumped. just gotta figure out a power supply for this EQ.
i built the ‘chassis' for the EQ a few months ago, turned out ok:
hoping to integrate the EQ onto the chassis sorta like this:
and getting to the end of this thread, ive just realized/queried something... can the PT sustain all this?
the 369BX PT secondary windings are rated 300V @ 86ma. (= 25.4 watts ?)
- my understanding is that 12AX7 triode current draw rating is [1.2ma at 250V], so 6 triodes = 7.2ma (x 250V) = ?~1.8W total?
- EQ circuit apparently draws 84ma, @ 33V , (= 2.8W ?)
to me, looks like the PT should be just fine.....
(all of my terrible maths/understanding on display here)
yes, this is a stupidly oversized build for a tube preamp.
it's no fancy 1RU build with torroidal transformers, printed circuit boards, and all the nice tidy things you'd expect to see with properly printed faceplates etc.
a lot of that stuff is beyond my understanding. i just do i what i can
the project:
(into FX return)
(into FX return)
