93ryans
Hey all, I just finished this build last night. It seems to be working for the most part, but with a couple issues. One of which I gather has been talked about before and may be more of a feature than a bug, namely the BBD hiss.
What I'm more worried about is that I get this weird, high-pitched, oscillator sounding background noise that jumps around a lot when the gate is open. It doesn't happen when the LPG is closed (so I hear it most when the LPG pot is all the way up), and it doesn't happen when there's no noise going through the circuit. It seems to be related to the BBD the same way the hiss is, but also possibly related to the Randomizer.
Here's a cell phone recording I took to demonstrate. Please don't mind the clicking sound, I believe that's just the footstool I was sitting on. There's no fan running or anything, so the hiss you hear here is mostly from the pedal as well. I mention the hiss as well because even though I know it's a feature of the original pedal, I wonder if mine isn't particularly loud... It happens both with and without the boost activated. I've screwed with the BBD trimpot a bit and it has a definite effect on both sounds. I'll have to fine-tune it a bit more though to see what I can do.
I got my V3207D's from Cabintech, via Ebay. I'm led to believe they're pretty reliable distributors.
I'm very close to finishing a Low Tide Mini as well at the moment, so I'll compare the two once it's done. Shot in the dark, but is there any difference between the Randomizer IC's shipped with the two versions? Cause it's very possible I switched them.
Lastly, could someone explain like I'm five, exactly what the BBD trimpot controls? I'm not especially clear on that at the moment.
Thanks for reading!
EDIT: The same noise happens both on my daisy chain (this was the only thing plugged into it) and on my Voodoo PP3 power supply. Both of those were plugged into the same power strip, but the PP3 being an isolated supply I didn't think that would make as much diff. Still, I'll try other power configurations and let yall know.
