Mach 1 no sound when engaged
ADAOCE
Have a Mach 1 that has no sound at all when engaged. Bypass and LED work fine. I’ve checked my solder joints. Didn’t see any cold looking joints. I touched up a few resistors so that the solder penetrated both sides. I even tried a different opa2134 and a tl072.
I’ve recorded the following IC voltages with the opa2134
1: 4.46
2: 5.03
3: 0
4: 0
5: 0.16
6: 0.59
7: 4.46
8: 8.2
I’ve attached some pictures of the board from the top side. I know it could use an IPA wipe down but to be honest that’s never resulted in an issue like this for me and I’ve done ones that looked worse.
mill have to wait til tomorrow to get a picture of the underside (I stupidly didn’t take a picture when I pulled it out to reflow joints). Underside looks better than top though since that’s the side I soldered from.
anyways I’m just hoping these ic voltages are enlightening. TIA
I want to go in through the back door to try and find where you are losing the voltage. If you remove the op amp you can back feed power from the socket, it may show us where the issue is. Using a battery is much safer than a wall wart, thats why I want to use a battery. If there is a short, you can feel the battery as it gets hot and remove it, plus a battery won't damage the circuit as long as the IC is out
Ok sounds good. You can leave me some instructions to try or I’ll just holler when I’m home from work and can get to my bench and we can go from there
Edit: just realized tomorrow is NYE. Happy new year!
Rigged this up at lunch. Will this be good? Only thing I had was this cable with a BNC connector on the other end.
The hardest part about this is hooking on the battery, the easy way is if you have an extra socket, you can plug it in the one on the board. If not then you need to be careful so you don’t mess up socket. Just need to hook up battery - lead to pin 4 and the + lead to pin 6 to start then we see what voltages are back to divider, hopefully we can find where you are losing it
