caiofilipini
Hi there,
This is my first post, and first PedalPCB build! It's my second ever build, the first one being a kit from Aion, which made a couple of things easier, especially wiring. I don't have much experience, so soldering skills are not great either, but the Aion build worked just fine.
This time around, I'm building the Mach 1 Overdrive (Greer Lightspeed). I've wired everything last night, and bypass signal works fine, but when the circuit is engaged, the LED doesn't light up and there's no audio coming out. A few notes:
1) I measured the lugs on the DC jack with a multimeter and the positive lug gets ~9.38V from the power supply. I also measured the same voltage on the other end of the wire before connecting it to the board. After wiring it to the board, I get ~0.15V on the wire.
2) I accidentally bought the wrong sized DC jack, so I only wired it up so I could test the circuit before the correct jacks are delivered.
Here are some pictures of the build:
I'm sure there's something obviously wrong, but without the experience, I can't pinpoint it myself.
Any thoughts?
Appreciate the help, folks!
Any thoughts?
