Just finished up this Mach 1 and realized I bought 2.5 mm plugs... guess I have to wait until I get a new plug to test it out (I usually don’t rock before I box... maybe I’ll start lol).
If you have alligator clips you can test it from a 9v battery directly to the PCB. Do you have them? Alternative would be if you have a DC jack from a different build to swap out temporarily.
I don’t typically use the switch plugs so I misread the schematic and I checked it with an older build using one of these and it was backwards. Probably would have fried something if I plugged it in!
Every pedalpcb board (that I’ve seen) includes a 1N5817 diode in series with the power input. This will prevent any damage to the pedal with wrong power supply (not all commercial pedals / diy pcbs from other sites / vero layouts have this feature, so generally should be careful).
