Madbean Current Lover
dcfvgb
Madbean current Lover aka Electric Misterss. Edit: Does a nice psuedo churos too!
Tayda enclosure, had some small tool marks and the bottom plate was painted a lil thick had to sand a touch, but for the cost? Drilled and powder coated for less than I used to do diy its well worth it. 99% of taydas work is impeccable.
My 4th flanger build, is the cleanest flanger I've built yet. I've also built the Madbean collosasus aka MXR 118 - much thicker, DeadendFX flangearama - ibanez fl99 clone using 2 x 3204 bbd's foot sw to use one or two in parralell This one can go from a nice flanger or chorus into "lets double it!" intensity, the deadatronautfx astroflanger aka electric mistress sans buffers that I liked, but the lack of buffers made it unusable
chaining with most of my pedals so I recycled it.
I think my next flanger will be the madbean kingmaker aka pearl fg1.
Asusual no fancy graphics, leftover paintpen smudge I'll clean after the paint is dry. Ya my phone sucks.
Sounds like you are on a flanger binge! May I suggest the ADA flanger? It's got a great sweep, gives you as couple of options with the even/odd harmonics and definitely can offer great modulation sounds at "chorus" like settings. I've built the mistress a couple of times, too,, but ADA blows it away. I'd love to see a 124b layout pcb for it, might have to request that one here. 'lectric fx has them. If you ever plan on doing the same with phasers the Final Phase is also worth picking up over there. I look forward to reading about that Pearl!
The Flintlock, have my eye on that too. Just looked up the countdown/ final phase , giving me gas!
