I mounted the output jack correctly, but the input jack is facing the opposite way.
Will the input still work? I've tried to get the thing off with a solder sucker, so far with no luck. ugh
I'm trying to do this. I can't desolder the jack, even after clipping the pins. I don't have much luck with solder suckers. I've also tried desolder wick, I just can't get enough solder out to remove the component.Hmmmm. you might even be able to clip the pins, turn the jack around, and resolder it to the pins. Worth a try.
Thanks - I'll try this!If you want to give another shot at desoldering you can try blowing the hot solder out with compressed air - just be careful what's behind it! But cutting it out and then desoldering would probably be the best option if you find yourself in danger of damaging the board.
Yeah the board was $20.cheaper to destroy the input jack than the testing board. everything is relative.
Ah - from the top. Yeah hopefully I can get my clippers in there.Just in case I was not clear, I am suggesting you clip the 6 pins on the top of the board to free the jack. then try to turn the jack arounds and solder it back into place.
Thanks for your help! The board still works. I did have to use a couple of wires that go underneath the board, but I built a Tommy III and tested it using the board.you should be able to still use your board. plug a cable into a jack and figure out which two pins on the jack connect to ground and to the tip of the cable. use your meter to see if those two corresponding holes on your board still connect to ground and to the input for the screw terminals at the other end of the board. If they do, you can go ahead and install the jack. if there is not continuity on the board you need to find a spot where you can connect to that trace -- probably by scraping some more of the pcb away near the hole. worst case scenario you un a wired on the bottom from those two jack pins to the bottom of the board where the pins for the screw terminal are located.
