Lobo da Mata
It worked with just one repeat (is it normal?) at home, then I took to the show and it worked for a few minutes and the delay started to sound like one of the crazy Chase Bliss pedal and reverse delay, I realized that the potentiometers were touching the metal enclosure and fixed it, worked for a few minutes and then I broke one of the wires and the show was over, I needed to took it off.
Got home and did the wiring again, but no success, you can see in the picture that the LED 1 is never working, no sound, in the picture you can see that I plugged the guitar signal to the output of the pedal, but even before it was not working. I am afraid the socket is not holding the 7805 and it probably damaged the ICs, the R102 maybe is not the ideal 4k7 value and it burnt the LED1.
What idea do you have? I saw some guys with similar problemas, but not the same.
![Magnetron 2.png Magnetron 2.png](https://forum.pedalpcb.com/data/attachments/73/73512-69cbd91ea43150c94789b04477e196e9.jpg)
![Magnetron 1.png Magnetron 1.png](https://forum.pedalpcb.com/data/attachments/73/73513-85bdd80f67e3f2704ad4cd7500e66fa0.jpg)
![Magnetron 3.png Magnetron 3.png](https://forum.pedalpcb.com/data/attachments/73/73514-c7b90d3be188ebbfed97a45e48af8b3f.jpg)
