AceHyzer
Hey all,
I have been working on a Mahayana Drive build. I’ve tested continuity everywhere it should be expected and as far as I understand the voltages are correct as well.
I’ve tried two different AD712s and an NE5532P and get the issue on all of them. Using an audio probe, I get signal up to pin 3 of the op amp and nothing beyond
Op amp voltages
Pins:
1,2,6,7, and 8 - 4.42V
3 - 4.25V
4 - 0V
5 - 8.86V
All legs of both mosfets are between 4.3 and 4.5V
I’ve checked and rechecked solder joints, continuity, measured pots, tested the Mosfets with my DCA75, I just can’t figure out why the signal isn’t making it past the opamp input.
Any ideas? Thanks!
Op amp voltages
Pins:
3 - 4.25V
4 - 0V
5 - 8.86V
Any ideas? Thanks!
