Mantle Fuzz - No output when engaged
nichgriff
Hello friends!
I have no output when the mantle fuzz is engaged. I'm very new to this and not entirely surprised - but thought I'd post to see if anyone had any thoughts!
I'm terrible at soldering and am working on it. I was really impatient and did not use sockets for the 4013 so maybe I fried that? But would that cause no sound at all? I also used an 1/8th resistor for one of them since I ran out of 1/4 but didn't think that would cause something like this?
Thanks!
EDIT: Works in bypass.
Do you get power to the LED? Do you have sound in bypass? Also it looks like you used stranded wire and there is some bare wire above the eyelets. I would reheat those joints and push the wire further in to maybe address stray wires that may be touching another component. Also make sure the underside of the board is thoroughly clean. This may help in troubleshooting.
Yes power to the LED and yes sound in bypass. I'll clean up those bare wires and give it a good clean again too.
A couple of things real fast. Google how to Tin wire leads, it will give you a better connection between the wires and the pads. This is a Must DO! when soldering. Next check the circled areas in the attached pic. The top one looks like input jack ground lead is missing. On the bottom one, is this a string or wire strand? IMG_4617.jpg
A couple of things real fast. Google how to Tin wire leads, it will give you a better connection between the wires and the pads. This is a Must DO! when soldering. Next check the circled areas in the attached pic. The top one looks like input jack ground lead is missing. On the bottom one, is this a string or wire strand?View attachment 7789
Awesome - I'll check them out. I just started tinning the leads but I don't think I'm doing it correctly haha but to be fair - they look much better than my previous pedals wires did so improvement! I'll take a look at them though and redo the ones that are bad. For the bottom circle - I was cleaning the pcb with a cuetip and a few hairs must've gotten stuck on it.
I was hoping that's what it was. All your parts seem to be correct, so hopefully its something easy. Some of the solder joints look cold, you may want to reflow the joints. Another thing that bites everyone in the butt, more than once I might add, is that we test the circuit either out of the box or with the back of the box off so we can see the circuit. It is common to plug the guitar and amp into the wrong jacks. Make sure you didn't do that. I once trouble shot a circuit for quite some time before I caught this. The only reason I caught this is I turned the pedal over and realized that when I did this the cables crossed over each other. That's when I started using my sentence enhancers to come up with some colorful sentences! :ROFLMAO: I switched the cables and everything was good. ( and yes I have done it more than once:LOL: )
I'll give them a reflow and see if anything happens! And I've totally done that too but triple checked that it wasn't the case haha I just ordered stuff to make a testing rig to not have to follow box until the PCB is tested so hopefully that helps sort stuff out. If the IC was fried - would that cause no sound to pass? Not sure if I should pull that out or leave it for now?
I've done this too.
If you have a multimeter check the voltages on the IC pins. Red tip to pin and black to ground.
If the op amp was fried, then no sound what so ever. If you fried the flip flop then you wouldn't have the octave effect but you could still have the fuzz effect, depending on the type of failure of the flip flop. Take the voltages like Buddy suggested. The NJM4558 should be easy. The flip flop will be weird on the readings. Pin 14 should be +VDD, if its >7Vdc then it should be good (didn't calculate value, but its 9V - Vfwd of D100 - Vr103). Pins 4, 7, and 10 should be at ground potential. Pin 11 will be an AC signal when you strum the guitar, check with audio probe if you have one. Pins 13 and 12 (Pin 9 is same as 12) will be a square wave and 180 degrees out of phase with each other, with no AC input(guitar strum) it will be a DC with one high and the other low. Pin 3 is tied to pin 13, they should be the same. Pins 1 and 2 are similar to pins 12 and 13. No AC input, one high and one low. (Pin 5 is same as pin 2)
