Marble Drive/Marvel Drive: add 3-band EQ?
Bucksears
Is there any way to insert a 3-band EQ into the Marvel/Marble Drive 2(3)?
I'd like more (global) tonal control - my Marvel 2 clone sounds great, but the controls (Normal Vol, Treble Vol, Presence) are really sensitive to changing the overall EQ, and it's tricky to find a good balance.
The Normal and Treble Volume are basically normal and bright gain controls and they change not only tone, but also saturation. There really is no easy hack, you'll have to either redesign the PCB or use an EQ board and essentially build a dual pedal.
EDIT: Also just noticed the Marvel Drive is essentially the same thing as the Colombo Plexi Breed (Golden Falk)....
