DGWVI
- Build Rating
 - 5.00 star(s)
Built to the doc, except R7 which is reduced to 470r for more lower gain range, and R18 which is 18k because I didn't feel like digging out a 20k
This is a pretty rad take on the transistor Big Muff topology. Gets rid of the clipping diodes and third stage filtering, and has had the tone stack tweaked to be relatively flat. Nice range of distortion- from a light clangy dirt up to not quite a wall of heavy overdrive. The tone control isn't nearly as dramatic as a traditional Muff, but I see that as an advantage as it's whole range is usable
I throw in some turbo Rat toward the end- the first with every knob maxed, then my daily driver Rat
Boxed up in a Bud Box CU452 with some knobs I got from a Soviet surplus shop a while back
Be sure to give this one a go if you're looking for an alternative to the typical 4 transistor Muff, especially the Fuzz War mkii which I find this to be most similar to. It doesn't quite as wacky as the War, but it sounds amazing
