I fixed R102 ..... Still not working
What do your voltages measure now? Do you get something closer to 9V on your 9V rail, or is it still ~7.7V?
Is your VREF closer to 1/2 of your positive voltage rail? When you have something seriously wrong with
the circuit that you identify and fix, you kind of have to back up and re-try your debugging again from the
start if it doesn't work right away because the thing that you fix changes the results of the tests you ran.
Do you have a way to make an
audio probe? It's not too hard to do, just a couple of components,
and it gives you a good way to figure out where in the circuit the audio dies. On a circuit like this,
you can just test the outputs of the op-amps to start with. The path is IC1/1, IC1/7, IC2/7, IC2/1,
IC3/1, IC4/1, IC4/7. Once you figure out the first place where the audio is missing, check the stuff
between the last good output and the bad output. (There's some nuance here, it's not really as
simple as A->B->C but it's a good place to start)
