Medusa Chorus (PPCB Caesar Chorus)
Nic
Build Rating
5.00 star(s)
Just finished this one last night. Everything worked as it should first try. That is really satisfying. It's my second chorus build after the AionFX take on the Small Clone and I took extra time on both those builds to pick the closest values I could find for each component. It really paid off in the end because with both of these builds, the bias was spot on right from the beginning. I tried to adjust it but could not get better.
I did not play a lot with it, but really like what I'm hearing. I worked many many hours to prepare the UV print based on an image found on google, and I love the final result, but the printing lifted when I punched the holes. The drilling did not made it worse so it's a win.
I almost used a glow in the dark enclosure, but ended with the more traditional pastel green. I used black aluminum knobs and switches and the result is probably one of my cleanest builds.
Here it is.
Looks great. Where did you get the art from? Or did you draw it?
I just googled for medusa images in black and white and picked a few that I liked and tried them to make a final choice. Then used inkscape to auto trace it and reworked everything bit by bit to have the image cut out of a black background.
