Microblend as clean blend
paulharvey
Have any of you used the Microblend added to a pedal as a clean blend? A friend of mine wanted a blend added to his danelectro sitar pedal. Looks like the Microblend might work well.
Looking at the schematic, it's a blender alrighty — so you'd still need to split the signal to begin with, I think.
Something like the Buff 'n' Blend could work:
https://forum.pedalpcb.com/threads/buff-n-blend-beginner-question.25148/
There are PCBs for the Split n Blend (called the Buff n Blend above) from other suppliers, as well as vero or perf layouts.
GGG has a simple splitter, as well as an op-amp based splitter:
Be aware there may be some phase/polarity issues, but there are solutions for those issues if you encounter them — it just means things start to get more complex. Snoop around the GGG site above and at least one of the op-amp splitters there has a switch for flipping the phase.
FuzzDog has a similar phase-flipping splitter circuit, IIRC.
Then again, maybe all you need is the MicroBlend. 🤷‍♂️
