Weird little issue with a Mofeta build. Volume works, both channels work, mid and treble work, pedal overall sounds like I'd expect. But the bass control does next to nothing. I swapped out a guitar in E standard for a bass in A standard (lulz), but nothing. Assuming my damaged ears were the culprit I fired up the analyzer in Logic, which shows mid and treble responding to knob turns but not bass. "Maybe it's the interface for some reason," I assumed, but running it before an Aion Lab and/or an MP-1 didn't change anything.
Bass pot (in circuit) tests as expected, going from approx. 1 meg to zero as its turned. I assumed the TMB tonestack would be similar to the schematic available from Coda, and it is (except the Mofeta leaving treble and going into power amp/saturation affair, I assume):
All points have connectivity where they should and none I can test where they shouldn't, 22nf & 270pf caps and 56k resistor look to be correct, pots are correct. I checked the electrolytics to make sure I wasn't choking out frequencies before they hit the tonestack, and those are visibly correct. I certainly can replace the caps and resistors and the pot, but I guess I'm wondering if there's anything I'm missing before I do so. (Or to be prepared if/when that doesn't work.)
The fact that the entire rest of the circuit works and this one small section doesn't makes me assume it's tonestack related, but happy to hear opinions.
