andyjperez
So I just finished putting together my MoFeTa today plugged it into my amp for a minute before I left for work and it sounded pretty good. Came home and plugged it into my modeler so I could listen to it with headphones, I was hearing a very faint chirp, so I popped it open and figured Iād fiddle with the bias pots and see if that would help the offending transistor. Went to adjust the Bass trimpot and GODDAMN!!! One of the 2N5457s in the bass sector was METHOD ACTING the part of a tube!! Hot as hell!! So I immediately unplugged it and brought it over to my bench, replaced the offender and checked all nearby solder joints, gave it another spin. Still hotter than a meth pipe on payday!! So I unplugged again and turned the trimpot all the way down, let it cool, then plugged it back in to see if thatād have an effect. Still Blazing like a high school stoner in a Honda civic. Wondering if anyone has run into a similar problem? Just looked at the schematic and it looks like itās Q4, not much going on there, looks 18v in from the charge pump and the trimmer, and one resistor to ground, so Iām not sure what I should be checking. None of the other components are getting warm, just olā 2N6L6 over here! Any help would be much appreciated, in the meantime Iām going to go look for some tiny eggs to fry.
