Thanks for confirming. It's hard to blame the “cheap tester” and ignore that the ones I purchased long ago (before having kids,) test as N-channel JFETS, and the ones when I got back into the hobby simply do not read as JFETS. (Just “NPN.”)
I'll never afford an Atlas tester to verify his claims that they're legit. My bad. He offered to take them back, but I declined, placing the blame on my tester. Wish I'd stocked up back in 2002.
… tester has been known to mis-identify / give false negatives in the past.
…higher than any of the prepackaged darlingtons i know of while the vf is so low, being lower than any silicon BJT i've ever seen tested …
Drain and Source are identical.What do you guys know about the cheaper Atlas, the DCA55?
Do you think it would correctly identify a legit J201 as a JFET? The datasheet notes that “only the gate pin is identified.” Probably doesn't bode well.
It's down to $70, which is cheaper than the last time I looked.
LMAO. I forgot; JFETs are usually symmetrical. Sorry.Drain and Source are identical.
I was awestruck that I actually knew thatLMAO. I forgot; JFETs are usually symmetrical. Sorry.
This particular style of unbranded ebay cheapie—it appears—
It knows when you've inserted a MOSFET as well. Pretty decent tester for $15.
- CAN correctly ID a 2n5457
- but CAN NOT correctly ID a J201
probably due to the test conditions Fig outlined earlier.
I've got one of these (or super-similar). It bricked itself (or I bricked it) just testing it out — never got to use it in earnest. Makes a colourful paperweight.
I had three different component testers in 3 weeks and each of them died inside a week. I ended up just buying a peak atlas in the end.That's a massive bummer.
I also have a dead generic tester: an induction/LCR meter. It never really worked. I wrote to the company name silkscreened on the PCB. They said, "we no longer support that product." I can't bring myself to throw it away.
Similarly, If I added up all the $25 DMMs that broke over the years, I could've bought a Fluke in the first place.
I’ve got a couple about 6 years in now… still going strong.!.!!Thankfully my middle of the road DMM has been rock solid for the last 10 years.
