I just got PedalPCB Mosfet Driver (BK Butler Tube Driver variant) soldered and I'm facing issues. Bypass signal works fine. Also led is working. When I turn the pedal on, I hear a lot of noise and a very weak distorted signal. Pots are working fine. I tried adjusting the internal trimmers and found out that the "best" way is to turn the left one full counterclockwise and the right one full clockwise. In this case I get tiny bit more volume (still much weaker than the bypasses signal). Here are attached a couple of pictures. What might be the issue?
Thank you all in advance
