MPF102 Substitution
chris.knudson
In the middle of a build that calls for an MPF201, which I cannot find. I know I can sub a J113 or a 2N5485, which I also don't have. Just wondering if I can safely swap it out for a J201, which I have plenty of.
I recently socketed a BSIAB which calls for 3 stages with those jfets. My experience was that the 2n5457 and thd j201 had a slight difference in gain, but the mpf102 was remarkably lower that the other two. I settled with the 2n5457 being in the middle.
The j201 and 2n5457 can generally be be subbed for an MPF102 without issue.
Ok, so I have both the J201 and the2N5457, which should I use for the Wavelord?
Why not give a reason "why" to use the 2N5457?
Is it the better choice because its gain, though higher than an MPF102, is lower than a J201?
I would think a J201 would be a better choice for a source follower biased to Vref given that the Vgs(off) for the J201 is 0.3–1.5V and the 2n5457 is 0.5–6.0V. A 2n5457 on the upper extreme of the spec could clip, right?
So much for me to learn still. I thought the J201 would distort sooner than the 2N5457
I need to sit down and figure out this Vgs business.
