Ginsly
I have one mentioned above (Crenova 890z), but I'm not sure how accurate it is when reading DC voltage... There have been many discrepancies between it and other testers. The only problem is that the OTHER testers are also slightly iffy - the TC1. I have two of those, and they both read almost identically - then I check the same resistor with the Crenova and it's way different. Fresh batteries and all. Checked a 9v battery against a dedicated battery tester and the Crenova, and same thing - different readings.
I'm starting to use the MM in a transistor-checking station, and I want to make sure it's as accurate as possible. Should I look into getting a different one? If so, what are some current favorites? I can't really spend Fluke money...
