Hi guys,
the past days i've build my Muzzle-Kit, buyed from Musikding Germany. The build includes the both switchable jacks for sidechain In and Out. For my opinion it works as well - tested sucessfully with the 2-, 3- and 4-cable method.
But i've a question about the threshold of the gate. Depended from the position of the internal range-switch, the "shutdown" (indicated by the colorchange of the led) occurs not before 10 o'clock (about 30% knobposition in "low range") or 12 o'clock (about 50% in "high" range).
My normal "operational mode" is the 4-cablemethod, with a muteable tuner in front of the sidechain In jack.
Now the quiestion... Is it possible to "lower" the threshold, to a setting below the described values?
I'am not so much familiar with "electrical engineering", but if i understand the schematic right, there are two resistors behind the internal range-switch (R8 and R10). Do i reach my goal by changing one of the resistors?
Greetings
Philipp
Greetings
Philipp
