SOLVED Need help checking voltages with a Sandspur.
ryugu
All I'm getting is a faint sputtering, and only with the fuzz knob turned all the way up. I tried several different positions with trim pots and got the same results. My only guess is that I overheated the transistors because I didn't use sockets. I was otherwise very careful building this. Where can I start with voltage checks? IMG_20221212_011905411.jpg IMG_20221212_011801489.jpg IMG_20221212_011831918.jpg
What’s going on here?;
In my experience, many problems like this are caused by bad joints, especially near the emitter of Q2 on the Fuzz Face.
Check this joint but in general check ALL your joints.
Q1 base looks like it lacks solder
As said re bias Q2 collector to around 4.5v ish set the sundial so you get 9v on lug 1 (fully CCW) then use the bias trimmer to set Q2 collector to 4.5v
*Edit I should say set the sundial to 9v ish that depends on what your power supply puts out and the little bit of voltage drop through D1 not all 9v adaptors put out exactly 9v especially unregulated one's
Yup, good eye. I accidentally soldered the left and right pots backwards, and had trouble with that one lug when I resoldered.
I think it's soldered thoroughly, but maybe I damaged the pots with too much heat or something???
@ryugu
Another PedalPCB forum "Troubleshooting Guru's" FTW!
I love this fuzz! Did you use BC108C's? I've read of some folks using BC183's for a slightly warmer sounding fuzz. I socketed my transistors and might give that a try.
You can mark this thread “Solved” by editing your original post title and selecting the the little drop down menu on the left hand of the title bar and select the “Solved” badge.
Helps with the hygiene of this forum so the guru’s can help the folks that still need help. Thanks!
Top Bottom
