robertbmillet
Hello! I have an older revision of the ungula (not sure which, not printed on the board) and it appears quite that some of the pads polarities are labelled opposite from the build guide, which confused me, so I went ahead and soldered negative to the square contacts on the board, which is standard practice but like i said, reversed from the build guide. the project is assembled, but I'm not getting any wet signal. true bypass is working, the main LED is working, and I'm getting 9 volts past D5, which I assume means that power is getting into the rest of the circuit, do i just need to reverse  D1-D4?
