ehguitarguy92
Hi there! thanks in advance for your help. New-ish user to building and troubleshooting PCB pedals specifically, but experienced with soldering and circuits/components in general.
Recently built a Nobelium circuit, but am trying to troubleshoot why it is not working. I reflowed solder on all joints, tested continuity at a bunch of points, and verified direction of polarized components, etc.
When I plug in power, LED's/tubes do not light up. Measuring ~125V instead of 250V at C1, as well as R10/R11. Voltage at those points fluctuates slightly...and the voltage at the input power jack is also fluctuating up/down regularly.
Powering with a 9v 1Spot wall wart that is working on other pedals - will try to grab another supply to test as well.
Do you think there is a short somewhere in the circuit? (I do not see any solder or component leads touching) Or are there specific places I can test voltage to isolate what the problem may be?
I do have a few more PCB's I have that I was going to build for local friends, so I can always build another to see if that one works, then test back and forth...but if you have any specific testing or troubleshooting advice...would be greatly appreciated.
Thanks!
Thanks!
