One is npn and one is PNP if I recallAren’t the two mostly interchangeable? The 06 has different gain correct?
The 2N3904 is an NPN while the 2N3906 is a PNP. Different gains, yes. But the polarity is reversed. The 2N3904 & 2N3906 form a complimentary pair.Aren’t the two mostly interchangeable? The 06 has different gain correct?
Of course. I got them mixed up with something else.The 2N3904 is an NPN while the 2N3906 is a PNP. Different gains, yes. But the polarity is reversed. The 2N3904 & 2N3906 form a complimentary pair.
Precisely why I gather and refer to the tons of datasheets I have on file.Of course. I got them mixed up with something else.
Just one more reason why Radio Shack went out of business...Mis-labeling has always been a thing . . . .
Already tested the BJTs with a Peak Atlas DCA75 and they are indeed 2N3906 PNP transistors. They all measured right in line with the 2N3906 datasheet.Actually, being that it is (was) Radio Shack, the next question might be which label is correct - the box or the chips???
Maybe you should test one to see if it's PNP or NPN ...
