NOS 2N3904 NPN From Radio Shack (NOT)
Cybercow
Not a question . . . more of "Notification".
Decided to crack open this pack of NOS Radio Shack 2N3904 transistors for a VFE-BumbleBee build and discovered why it is so important to dbl-check one's part BEFORE installing.
The pics say it all . . . .
Mis-labeling has always been a thing . . . .
Actually, being that it is (was) Radio Shack, the next question might be which label is correct - the box or the chips???
Maybe you should test one to see if it's PNP or NPN ...
Already tested the BJTs with a Peak Atlas DCA75 and they are indeed 2N3906 PNP transistors. They all measured right in line with the 2N3906 datasheet.
