You should be fine, the main issue would be that the trace is unbroken. If you wanted, you could look see if there is continuity between the exposed trace and the nearby holes, and then test between the two holes that tested at each end of pled area. You can possibly also see (by the subtle raised lines in the lack coating where the trace runs.
