Does the Nudrive pedal assembly come together like this?
And if so, this would prompt a hole to be cut in the pedal case to allow for room for the Nutube to stick out the top, right? Sort of like the Muffin Factory's DIP switches? Thank you!
Nope, the module goes on the other side of the pcb atop the ICs. And the Tone pot is flipped 180 degrees to point the same way as the other 2. See page 4 of the build doc.
