dot matrix madness
I'm using pretty much the same solder/rosin combination Sn60Pb40 without any problems, and that stuff is from the 70ies.
At least it's safe for drinking water applicationsI'd use it. But I'd also keep a bit of flux handy. I use this with any old solder I find without issue.
Oof. That's some pretty nasty flux. Be careful with that stuff. Zinc chloride and ammonium chloride. I don't think the zinc is as big of a concern, aside from on skin, but doesn't am.onium chloride offgass as hydrogen chloride when heated? Don't want to be huffing those fumes.
I'm no flux expert, but I also clocked that Oatey as being for industrial pipe work and whatnot. Careful @Cybercow!I don't know anything about the chemistry, but that looks like the stuff I use for soldering copper water pipes together. Might want to look into plumbing vs electronics solder and whether that's the best stuff for the job.
Don’t tell that to Nathan Fielder…
I don't use a lot of flux generally, but I have a Kester pen that makes desoldering a LOT easier.
Well, at least I don't chew on my solder. As for off-gassing, it takes 640°F to get ammonium chloride to break down and off-gas. I solder at lower temps than that. I don't touch it with bare hands and carefully wipe up any excess and use alcohol to wash my PCBs after population. Not my first rodeo with hazardous chemicals. Cheers!Oof. That's some pretty nasty flux. Be careful with that stuff. Zinc chloride and ammonium chloride. I don't think the zinc is as big of a concern, aside from on skin, but doesn't am.onium chloride offgass as hydrogen chloride when heated? Don't want to be huffing those fumes.
Holy shit! Any of that kind of flux that is left behind (including any fumes which land elsewhere on the circuit) is quite corrosive, I would *not* recommend using this on electronics. That stuff can really chew up your pots down the road.I use this with any old solder I find without issue.
He’d be able to figure it out. He graduated with really good grades.
That's why I don't touch the stuff with my bare hands. And when/if I do, I stop and wash my hands. I also wash my PCBs, after population, with 99% Isopropyl Alcohol; then wash with soapy water, rinse & dry well.Holy shit! Any of that kind of flux that is left behind (including any fumes which land elsewhere on the circuit) is quite corrosive, I would *not* recommend using this on electronics. That stuff can really chew up your pots down the road.
For electronics I am a big fan of Superior No. 30 SuperSafe liquid soldering flux - water rinsable, and totally noncorrosive.
It can be hard to find, but it works great - I've had the same container for more than 20 years.
It works best if you're using a soldering station from the same decade.I've still got a roll or two from the 80's that works fine. YMMV
Another vote to just try it.
Yeah, I have a spool. Less shiny joints than 63/37 w/ type 44 rosin, but also a slightly lower melting temp. Mine came in an expired lot from a friend who works as a tech in aerospace applications. You can make it look shinier by using desoldering braid on your joints, which I tend to do for SMD opamps and not much else.This was among them... 62/36/02. Not familiar, but seems like some really like it. Anyone use this type?View attachment 97923
Ah - missed that it's not a 44 rosin. Good info, thanks much!Yeah, I have a spool. Less shiny joints than 63/37 w/ type 44 rosin, but also a slightly lower melting temp. Mine came in an expired lot from a friend who works as a tech in aerospace applications. You can make it look shinier by using desoldering braid on your joints, which I tend to do for SMD opamps and not much else.
