OPA4134 - what should I build?
ftumch
Got one of these bad boys lying around and I don't know what to build with it - any recommendations?
I tried it with a Belton Brick but the hiss was murder - I put that down to the extended frequency response
Like the TL074 and other quad amps its often used in multistage preamps and equalizers.
Yeah that's a good point. I'll do some digging
Thanks for the suggestions everyone
Just a single chip? I've got gerbers for a 6 band with footswitchable boost that loves fancy ICs.
I really do agree using high slew rate ICs for clipping doesn't sound that great
Yeah just the one quad but I've got a tube of duos. I'd be interested in that gerber mate
No problem - I did have separate switching PCBs for it, but I'll do some rejigging to get everything onto a single PCB so they're easier to get made.
The first version I made did need an 18v supply, but I've changed over to an isolated DC-DC converter to make them way easier to power.
Cool mate sounds good. I've been messing around in Diptrace with charge pumps and such this week. Will be putting in an order in with JLBPCB in a day or two. I'm new to PCB design and I've been quite ambitious so far lol. Will see how that goes
Just letting you know I haven't forgotten - I've redesigned the board for an onboard isolated +/-15v power supply (that actually meets EMC class B regulation), and redoing the layout to reduce the noise floor even further (it was already pretty good on the original, but I reckon I can get lower). There is 1x SMD inductor on board, but it's pretty big and a real easy to hand solder.
I moved all the groupings of filters around to optimise the layout as much as possible, so we should be able to get this thing perfect. You also have the ability to change your filter centers/Q pretty easily - I've got octaves from 80hz and matching Q's all the way up the board, but you might want something a little different.
Cheers
Cheers
Almost done - just need to finalise a few things to make it as easy/cheap to make as possible. Using a fully isolated onboard switcher to get +/-15v rails, and I've included all the components to meet EMI requirements - there are a couple of SMD components required, but all very easy ones to hand solder. I was originally going to have the boards stackable with pin headers to connect them, but I think I'll go back to my normal ribbon cables as they make the entire thing smaller (and IIRC I think the whole fab cost comes down a little bit).
Finished.
I've added the PCBWay direct output and a BOM - everything is pretty straight forward and easily available. It does require a DC-DC converter (which I moved onto the switching PCB to massively reduce the radiated noise potential), and if you grab the datasheet for it the recommended cap/inductor to meet EMI spec is listed.
I have built the EQ section before and it worked great, but the power board is untested. I've had a couple of people look over it to check I haven't missed anything and I think we're good, but no guarantees are given/etc. The only change I'm going to make is to use a couple of SMD quad opamps with an adaptor, and have SMD decoupling on the back of those adapter boards.
The only thing I would be mindful of while building is cutting component leads short once soldered to ensure they're not shorting on the back 9mm pot leg (you can just cut this off if you want too).
@drew.spriggs ah mate I didn't thank you for this - got sidetracked
Looks wicked. I'll be putting an order in for more PCBs next week so I'll tack it on
Just testing some stuff now. Might be able to return the favour all being well
Go for the Goat of overdrives, the Madbean take on the VFE dragon. His new layout will handle that bad boy
