marioandluigi
Hi,
i am new in this forum and from germany, so please excuse me if some terms are not correct.
I have build the Organ Donor, i think all solder points are correct.
The Bypass signal is there, but when i switch on the Donor the light shines but there is no effectsignal. At the beginning is a short crackling and than only the dry signal (of course only if i dial in the dry knob).
I have no idea whats up. maybe an IC is defect due to soldering? IC 1, 4 and 5 are soldered on a base (so there should be no problem), only IC 2 and 3 are soldered directly onto the board. Before this project i have had another project and there was the problem that the L78L33 was defect (no signal was coming through), could this cause this problem too?
Kind regards,
Mario
Kind regards,
Mario
