No. That would be a faraday hat.I am still a bit curious about the original question about a Farady's cage here. Is an enclosure without a lid still 75% such a cage? Or is it "all or nothing", eg. better ground the lid with the rest of the enclosure?
Everything needs to go to ground.
Cracks are way worse than holes. Any crack will allow rfi passage of a frequency with a wavelength 4x it's length. i.e., 1 Ghz is 30 cm, so it and any frequency at or below 1 Ghz could pass through a crack of 7.5cm.
If the material is ungrounded, the RFI will only be attenuated.
