SOLVED Paragon channel 1 isn’t working
phintze
I wired up this paragon today and channel 1 isn’t working at all and channel 2 doesn’t seem to have much gain available. Anything obviously wrong with this?
Your solder could make do with a reflow. Some of the pads look like they have no solder at all. I’m sure they do, though. The solder should flow through the hole. Also, check all the values to insure nothing is off there.
It turned out to be a grounding issue. I think one of the pots was contacting one of the solder points somewhere, but I managed to fix it.
