vinealmeida
I've recently built the Paragon Mini and the pedal sounds great. The only issue I'm having is that on both channels the volume is kinda low. I need to have the volume at max to have unity, and that happens on both sides.
Both sides sounds exactly the same when using the same settings. So far I confirmed all resistors values against the build docs and all is correct.
I'm using a charge pump and confirmed both ICs are getting the proper voltages.
For this build I'm using a LF353P (I also tested a couple other ICs andI'm having the same issue). The diodes are 1S1588s and 1N914s.
Any ideas on how to increase the output volume or any errors I might have done during the build?
