ddavis20341
I'm having some issues with the Paragon builds that I'm working on right now. I'm building 3 of them - 1 for me and 2 for friends - and all three of them are having the same issue.
They work fine out of the box, but when I go to put them in the enclosure, something shorts/grounds out and the signal cuts out. This is usually on channel 1 (2 of them have channel 1 cutting out, the 3rd has both channels), and additionally the tone knob on channel two then starts also controlling the volume. I was wondering if the tone pots are where the pedals are grounding, so put some electrical tape over the tops of the legs and also over the 3 holes right below the shaft, but that didn't seem to make any difference.
It seems to only happen as well in the last third or so of tightening down the components - everything works fine until you hit a certain depth, at which point you can hear the tone change from the tone part starting to control the volume, and the channel cutting out.
Just wondering if anyone has any tips/has encountered this before. I'm a little bit stumped right now since I don't see anywhere obvious for things to be grounding out. I also have plastic seals on the bottoms of the pots, and have tried re-flowing a bunch of the connections to see if that makes any difference. Thanks!
(Sorry for the bad lighting in these pics, I can upload better ones if needed)
