Parentheses Fuzz with Intelligent Relay Bypass
ozdixon
Hey everyone, I am having some issues with the Intelligent Relay Bypass on the Octave switch for Parentheses Fuzz. I am getting no octave effect, both boost and fuzz work. There is an insanely high noise even with gain turned down. When fully Turing octave pot the there is no sound, other wise it has no effect. The momentary switch doesn't have any effect. When I turn it on the octave led blinks and either stays on or give a click and turns off. It seems to alternate randomly.
hey i just wanted to let you know that i was having trouble looking for info on how to use the intelligent relay system with the parentheses pedal, until i used your photos for reference... the pedal works completely fine for me! i have no issue with the octave knob, and everything works as it's supposed to. so thank you for posting the photos and i hope you get your pedal fixed.
as for your problem, maybe list the resistors/capacitors/other parts? i can let you know the exact parts i got so you can compare, if that helps
Hey, I started over with a new PCB but was still having troubles.
With the new PCB I needed to jumper from R22 (2) to the third leg of the filter pot.
I don't know if there was an issue with the board, or if I made a mistake, but it works now.
Thanks for verifying the relay set up.
