finebyfine
Everyone's gotta do the full size at least once I suppose. Fired up 99% perfectly right off the bat, other than some trouble with the expression jack - and I'm not entirely sure I nailed it down - I think my expression pedal is shitty. When wired to a potentiometer the way an expression pedal is usually wired it behaved as expected after switching to isolated jacks.
I forget what BATXX diodes I used for the octave instead of Germanium off the top of my head but they seemed to help the octave effect better than the germanium diodes I used for the clipping.
I've done the mini for myself but got the opportunity to do a full size one as a commission. I like doing non 125Bs when they're not personal builds, I rarely feel like an effect warrants that much pedal board space, even though my pedalboard is an absolute disorganized mess.
I will say surprisingly I think the mini is easier to box up - there's sort of a tradeoff between the two where the mini is harder to populate and solder, and this is easier. I should have positioned the expression jack better but was locked in with where the print ended up.
