Parentheses Mini - Quiet in Bypass, quiet rat.
If it's quieter than it should be in bypass then it's switch issue. Or a soldering issue on the switches or sockets. I can't see how it could be anything else. Crazy idea - have you tried different patch cables?
No. But I did a test with the same patch cables with other pedals and even direct into the amp no pedal and there is a huge difference.
Could a cold solder joint make the signal come through at half volume if it was like that on a switch? And that’s also where in bypass, no effect on it’d still be quiet? I means that’s the part that perplexes me.
With the pedal PCB daughter boards for the switches. Maybe I’ll play with the switches on and off independently a bit more and I’ll be able to narrow it down as to which side is the issue.
