dont-tase-me-bro
Stupid question and I assume the answer is yes, but figured I would ask:
I have a bunch of pedalpcb boards all populated and was going to put them in a 2u rack enclosure with regular in/out and power. I was going to omit the LED and the 3PDT so they're always on. I was going to use an external switcher and patch bay to put them in and out of the signal path.
Will these boards run without a switch?
I figured they would but I just got a Low Tide Modulator that has a breakout board with it. From what I could tell it seemed like I could do the always on thing with it, but I'm not sure. With it being attached to the main board makes me question it. Like, assemble the bed and have a bag of bolts left over that say "load bearing"
I've built a ton of stuff, but I'm more of an assembler and avoid straying from the set layout typically. Pretty sure this would work, but also except the answer could easily be, duh of course this won't work.
Thanks,
Pat
Thanks,
Pat
