I look forward to your feedback! It’s a pretty straightforward python program so it’s pretty easy to update with any changes you want. Also when you close out docker, the database will stay persistent so you won’t loose any progress you’ve made with adding things between sessionsI’ll check it out later tonight and give you my thoughts
It’s only like that for now until I fully deploy it on AWS. Which I may if more people use it and like it!Oh boy command prompts… feel like im 12 trying to redo my autoexec.bat file to free up enough conventional memory to play quest for glory
I’ve never seen that one before. I’ll have to download it and give it a try.I use the Odoo community edition for this, cause it's already designed for manufacturing it has all the functionality you need, luckily all available in the free edition.
It looks like you did not upload the actual project files, all I see is README.md. No other branches or releases either.It's alive!!
Forgive the horrible formatting of the readme on the page, but if you download it, it's nice and neat!
GitHub - itsmedant/Inventory-App: A lightweight docker based app to keep an inventory of your pedal parts!
A lightweight docker based app to keep an inventory of your pedal parts! - itsmedant/Inventory-Appgithub.com
Let me know if you have any trouble running it!
Let me check, I was trying to quickly just get it pushed. You can download the zip and extract it and deploy the compose file into docker (or should be at least)
Yea i ran into the same thing. Was having trouble with docker on my desktop in my music room/bench area. Windows home 10, was trying to get it working through powershell. After a lot of research and trying stuff that just did not work (which apparebtly is very common based on my google searches). Ill try with my windows 11 laptop later today.It’s only like that for now until I fully deploy it on AWS. Which I may if more people use it and like it!
Okay, seems like its not parsing correctly again. Let me do some tests on my side to see if it can replicate it. I may have you send me a sanitized version of your pdf if you don't mind. I jsut put in a tayda order so I can try it with mine!So i uploaded the pdf from my most recent tayda order and this is what it showed.
Post when its good to go and I’ll give it a tryAhh I figured it out. When the PDF got loaded, the lines got mixed up with the parser function. I think I got it sorted! I’ll get a new version updated today!
