PedalPCB Caesar Chorus/Walrus Julia
OD is Glorious
Build Rating
5.00 star(s)
The chorus circuit sounds chorusy and vibey abd stays at unity when engaged. This circuit brings you back to the sound of the 1980s. The toggle switch is an SPDT on/on and switching it back and forth does not bring discernible changes; it is subtle like all the other Caesar builders have said. I think somewhere on the boards Robert suggests swapping out the two 3mm LEDs that are in case. If you like chorus this circuit lets you control your modulation well.
I used a white 125b enclosure and I applied a waterslide decal. If I had to complain about the decal I would say maybe it is darker than it needs to be. I protected the enclosure with Spraymax 2k clear. I used enclosed top jacks and a PPCB top jack plate: note that I used epoxy to hold the D.C. jack in place for long term stability. I used these 16mm white boss style knobs. I have a dress nut on the toggle switch, it is from Amplified parts. If you want to buy one of these make sure you get this type. Others have a lip that does not allow you to use this as a nut. You need to make soure you get "Dress Nut - threaded through, for Mini Toggle Switches". These chamfered edge ones are nonsense IMO.
The rate indicator LED is left of the footswitch and it is a clear blue 3mm in a clear freznel. The bypass LED is right of the footswitch represented by a 3mm clear red LED in a freznel. FYI: The original Julia has the LEDs opposite,
The build has a few uncommon parts: for starters IC3 V3207D BBD Analog Delay Line and IC4 V3102D BBD Clock, Two-Phase. The 8n2nf capacitor is not common and neither is the Zener diode 1/2W, 9.1V.
Notes:
  1. You need a Zener diode 1/2W, 9.1V PPCB has them
  2. You need a V3207D
  3. You need a V3102D
  4. You need a 8n2nf film capacitor
