PedalPCB Chop Shop
5.00 star(s)
5 Stars for “build experience” but I don’t really love the pedal (and I really wanted to). First the build: I watched the Fairfield Circuitry Barbershop V2 teardown video on YouTube where the guy gives the exact specs for each J201 - and I was psyched to nail both of them dead on from my stash. That made biasing super easy (though I had to turn the trimmers more than I expected). Beyond that, it’s a low parts count, nicely spaced, easy build.
Stamping the enclosure is never easy, but I’m getting better at it. I’m just glad Fairfield Circuitry doesn’t have all their lettering neatly lined up! All I have to do is try really hard to line everything up perfectly and that ensures it’ll be pretty jumbled like the real thing 😅. I 3D printed a jig with some PLA CF for strength and that helped a lot. The file was for different sized punches, but I scaled it down to get it very close.
Now for the pedal. I love low-medium overdrives. I loved a lot of demos I watched. I loved seeing Jeff Tweedy rocking one live a few weeks ago… I just don’t love mine. I knew it would be dark. I knew the “sag” control was going to be subtle (and not like a “starved voltage” breakup like the ~900 Fuzz or the “Big Cheese”), but it’s a bit TOO subtle IMO. I also would have appreciated a bit more differentiation between the down and middle positions on the “tone” switch. I’ll probably appreciate it more when I find the right pedal(s) to stack it with. Still experimenting (and open to suggestions)!
I never understood why people wanted the tone switch to darken this
Right? I know dark is kind of their “thing” but would it have killed them to have a little more flexibility? As it is, from bottom to top, it seems to go from overly dark > almost imperceptibly darker > unusably dark. My main amp is an original 1965 Deluxe Reverb with no bright cap mods, so I’m starting off pretty damn bright and this pedal is still quite dark.
But even counteracting that with my Guptech pPTSD parametric EQ, I just don’t find the gain/range all that likable and the “sag” as I mentioned does very little. I own more overdrives than I’d like to admit and as of right now, I’d reach for pretty much any one of them before this. Was NOT expecting that at all.
I put mine in a 1590BB with a bright and hard clipping OD first in the order, which is basically the only way I can get any mileage out of the sag control, heh. together the combo sounds really trashy in a way I enjoy a lot, but I’m surely in a tiny minority there.
I love stacking pedals and the endless combinations are a good excuse (defense) for how many I have. But the fun of that is expanding on pedals I already love. Trying to make a “meh” pedal usable doesn’t have quite the same draw haha.
Looking forward to some mods from @Morbidpale
I’ve heard the Barbershop sound too good to give up on it so easily.
So I got out the pedal and what sadly are terrible notes. I remember liking this thing but not so much now. 🤔 so I got out my smallsound/bigsound mini because I know i loved it. But then I was pouting and thinking of how to redo it so it's better. I guess I'm just over fet based drives. I can't praise hudson broadcast as the best drive ever. Thats my 2 cents.
The chop shot certainly benefits from having a mild compressor in front to hit it a little bit.
Q1 is set to be 0.6v - 3.6v at the extreme ends of the sag.
Q2 is 1.5v - 4.8v
The tone switch I changed to 15n but could be bigger still. Maybe 22n.
I could have sworn I swapped the 47n to 33n but I guess not. Worth a try. I will say 47n sounds good when the sag is set for high voltages and gain is high. Its way too bright without it.
If I was working on it now id probably change the switch to a at the very least a low pass filter. Or maybe a notch filter to slightly complicate things for fun.
I would never use the Barbershop as a stand-alone pedal but it does make an excellent booster. Same with the Broadcast IMO. I admit to being puzzled by both pedals when I first tried them - the breakup is quite harsh in each. But often that makes for a great sound into an already breaking up sound. Smooth into smooth can be too much of a good thing.
True that. The broadcast works best at almost breakup and then when you dig in you really start to hear it. Very reactive.
Although after decades of trash talking tube screamers I'm suddenly like "maybe I like these now?". So any opinion i have might be worthless now. 🤫
