Here's a verified Obsidius template with smaller holes for the toggles. Built it this week. Perfect alignment.
The LED is for an off-board 3mm LED with no bezel. Increase the size for use with a bezel.
(Incidentally, my first version used an LED hole in the exact spot on the PCB, which works fine, but it's too close to the pot below it for comfort. Also, the LED in practice is hidden behind the knob from real-world stage angles. I've moved the LED to a more visible location in the above template.)
