Fingolfen
- Build Rating
- 5.00 star(s)
Pedals for Ukraine has been a bit quiet lately, so I talked to the guy running it, and we're going to try and jump start it a bit...
My first Boss Blues driver pedal was the standard model. However, I'd recently finished up the Galaxie mod of the BD-2 pedal, and thought it would be nice to create something sort of unique for the auction, so I dove in and populated a second AionFX Sapphire board! As with all of my recent builds, this one includes high-end metal film 1% tolerance resistors, metal film capacitors (KEMET and WIMA), Nichicon electrolytic capacitors, and genuine Toshiba through hole 2SK184-GR transistors.
The wiring follows the normal AionFX recommendation for grounding with a star ground to the input jack. I'm using ribbon cable to connect the 3PDT daughter board to the main PCB. The hookup wire is all 22 Gauge aerospace grade wiring. The LED is a golden yellow color to go with the blue and yellow theme of the overall pedal.
The pedal is named after one of the few dinosaurs that has been discovered in Ukraine - the Riabininohadros. Sadly after it was together I noticed a typo on the enclosure, so the winning bidder can either get a free replacement enclosure, or have the satisfaction of knowing that they'll have an absolutely unique pedal as any additional pedals made will have the spelling corrected...
A tiny bit more at the blog: https://steggostudios.blogspot.com/2022/07/boss-blues-driver-with-ukrainian.html
