Pendulum: no sound
yangushii
Hello everyone,
I have just completed the Pendulum Harmonic Tremolo. But I am getting no sound when the effect is on. (Sound goes through when bypassed)
The on Led is lighting up and the LFO led is blinking and the speed pot is changing its speed.
I can also hear a feint ticking of the tremolo which changes as well when turning the speed knob.
But absolutely no sound is output even at maximum volume volume pot.
I did not use a dust cover on the volume pot but isolated it with red tape.(same as the one i used on the led/sensors from the picture)
Having no schematic and little experience, I am not sure how to troubleshoot this.
Any help is welcome :)
It looks like your bottom ic is upside down, additionally your foot switch breakout board is upside down. You should also connect the grounds from the board to your jacks.
Build doc.
You are correct indeed. That's quite a shameful mistake. Thanks for pointing this out. I've corrected both but still no sound. I will look at voltage around that IC pins when I have a bit of time and report back here.
Y.
A picture of the under side could be helpful, I would also suggest grounding your jacks per the wiring diagram. I would reflow, and if you have an audio probe start tracing, if not make one and start tracing. I still suspect your foot switch is the problem or at least part of it.
Thanks Carlinb17!
I followed your advice and re-wired the switch completely: It now works like a charm!
It does sound brighter than the dry signal but I guess that's part of the circuit (i see some post regarding that in the forum)
Thanks again for the help.
Y.
