Digikey, Tayda (ebay and Amazon), and several other vendors have B200k in split-shaft.
Since it's a trimmer being bust out, then you don't need the long legs of a PCB-mount.
Why A200k?
The trimmer is B200k, why not go with a B200k?
250k would do, but it will change the EQ point at the far end of the dial.
Sharvie has one with a plastic shaft.
You could also use a dual-gang 100k, and bridge the first gang's lug 2 to the second gang's lug 3.
Input goes to the first gang's lug 3, and the output comes from the second gang's lug 2...
Wait, that won't work as lug 1 isn't going to ground.
Another option is to go with a 500k pot and stretch a 360k resistor across the outer lugs, gives you 209k
330k across the 500k pot will get you 198.8k.
OR
take a 250k pot and put 820k across the outer lugs and you've got 191.59k; a 910k resistor across a 250k pot gives out 196.12k
BUT
a 250K pot with a 1M resistor across it will give you ...
200k !
The taper of the pot will be a little wonky compared to a straight A200k.
Read Keen's
The Secret Life of Pots for what constitutes "wonky".
It's a bass control... it's not like anybody uses those or needs them.
I'd just go with B200k.
