BrainDrain
Would lowering the value of R14 to around 1k-3k have any negative impact on the LED/LDR? Or do they not have any effect on each other since they’re in parallel? The 10k is too much for the green bypass indicator LED I want to use. I have a Yellow 5mm from Tayda connected to R15 and the 10k seems fine for that since it’s quite a bit brighter than the green.
